Trying to work out if, or how well the above shock will fit on my Bandit using a bottle and cage at the same time.. I think i'll have to use a bracket to Move the cage down towards the seatube but theres still not tons of room for a piggyback reservoir.
I need to know from the eylet holes how much depth the resevoir takes up.
Cane Creek is the backup, more expensive option..
No issues on a L 2012 Frame with a Monarch plus. Swapped out for a standard rt3 debonair now tho.
Why not use the bottle cage mounts under the downtube tho?
The bottle will get dirtier, simple! Also not so easy to reach on the move. Why the switch to non piggyback?
Anyone?
I'm not sure if it's any help or not, but I've got a debonair monarch plus on my carbon covert and there is loads of room around the piggyback.
Obviously biggest difference is my shock attaches to the down tube whereas yours will be on the top tube which may interfere with bottle placement.
I can measure mine in the morning if you like??
Yes please
