Rockshox Lyrik Utu...
[Closed] Rockshox Lyrik Uturn coil service Help pls
3 Users
First time I have taken rockshox apart.
There was no oil to drain out 😯
No foam rings to clean.
So after cleaning I've greased the seals area and put 15ml of lower mix in the bottom of each leg
All good simples 🙂
Problem is I now have a knock sound after they have been compressed and return to full travel.
Any ideas what I've done wrong?
Also how will they be better now they have oil in the lowers ?
Posted : 15/08/2012 4:41 pm
did you tighten it all up?
Posted : 15/08/2012 4:45 pm
I did this.
http://www.cycletherapist.co.uk/step-by-step-guides/rock-shox-lyrik-lower-service/
Posted : 15/08/2012 4:48 pm
One for the Tftuned boys by the looks of it.
Posted : 15/08/2012 8:51 pm
Drop Loco (Simon) a call and see if he can help, if you still need to send them off he'll do just the same as TFTuned but cheaper 😉
Posted : 15/08/2012 8:55 pm
