Rockshox Lyrik help
[Closed] Rockshox Lyrik help
3 Users
Do the newer Lyriks not come with a 150mm option?
Failing that is there a 150mm air shaft available?
I've tried looking and can only assume it doesn't exist.
Posted : 03/08/2017 10:59 am
According to the RockShox SPC 2018, the 2018 fork is the same as the 2017 in respect of the air shafts.....
"Air Shaft Solo Air - PIKE (160mm 27.5/140mm 29), Lyrik/Yari/Pike 29+ (150mm)"
Part number - 11.4018.026.001
(As you can see, same as a Pike 160mm for 27.5 fork so should be readily available)
edited because I checked on the importer/distributor website and they are listing the 150mm model...[url= http://www.zyrofisher.co.uk/products/detail/RS9658006 ]ZyroFisher 150mm Lyrik[/url]
Posted : 03/08/2017 11:16 am
29" comes in 150mm, no 27.5 option, but can be sorted with an air shaft:
https://j-techsuspension.co.uk/products/rs-pike-air-shaft-160-27-5-140-29
Posted : 03/08/2017 11:26 am
Yes - that's the same air shaft that I've already given the part number for !
Posted : 03/08/2017 11:30 am
