Rockshox Lyrik - Ca...
[Closed] Rockshox Lyrik - Can I use lock dial without the remote?
2 Users
Does anyone know if you can use/turn the 'Open' and 'Closed' dial without the remote lever?
Same as this one:
https://www.worldwidecyclery.com/blogs/worldwide-cyclery-blog/rockshox-charger-2-damper-with-remote-lockout-customer-review
Posted : 07/01/2020 8:14 am
You can on older Rockshox models. You have to open them up and unhook the return spring as it is the lever that holds it in place. With the spring unhooked it can be used as a manual dial. Don't know if it is the same on the newer models.
Posted : 07/01/2020 8:26 am
Thanks, I am not sure you can on this model (2017). But maybe some knows a hack! Not too bothered as will probs leave it in open the whole time anyway.
Posted : 07/01/2020 8:38 am
