Rockshox fork servi...
[Closed] Rockshox fork servicing - will I die?
5 Users
Just taken receipt of my rocketmax. Some bike. Climbs, descends, jumps, pedals better than the bike it's replacing. Class.
However, not surprisingly, I think the lyrik ultimate is dry from factory. Oil's on order to do a quick lowers service. When I serviced my girlfriends revelation a while ago, when trying to tap out the damper using a T handle allen key, rubber mallet and the red aluminium rebound bolt that sits in that side I managed to destroy the bolt before I could shift the damper out. Oops.
To get round this, I took the steel bolt out the air side and put it in the damper side, then the damper came apart from the lowers side no bother.
Is this a bad thing to do? I am probably overthinking it but I really don't want to wreck the fork as soon as I've got it!
Thanks in advance!
Posted : 24/04/2021 9:35 am
Bumping to make this show in the main forum
Posted : 24/04/2021 9:36 am
Sounds sensible. Can't see this method causing an issue so long as the threads are the same. I've always used a punch and metal hammer to tap them free and had no issues.
Posted : 24/04/2021 9:45 am
Awesome, thanks for the reassurance!
Posted : 24/04/2021 10:26 am
Sounds fine. I undo the bolt 1 turn at most, give it a clonk, then repeat until it comes free.
Rockshox are great for online support and not needing a million specific tools, shame my new bike has Fox forks (won't even mention the Lefty on the winter bike!).
Posted : 24/04/2021 10:27 am
Suspension is the last thing I've properly touched on a bike as I was always quite intimidated by it.
This was until I pulled a Yari completely apart and rebuilt it after a lowers respray. They are really easy to work on and now I've got something nice and custom (mostly by my own hands).
echoing above, I only free the bolts up two turns before I get to whacking. After that, it's a bit at a time until the air spring and damper are free.
Posted : 24/04/2021 10:32 am
Ok, thanks for the tips, I'll try this when oil gets here
Posted : 24/04/2021 10:40 am
I did the same on exactly the same fork as you have - just a turn or 2 then a knock to free it. Wasn't a problem. I would think especially with a new or fairly new fork it should all go as per instructions. Probably due another lowers service actually.
The small amount of oil for lubrication on the spring side made a difference to mine. Perhaps dry from factory. It also freed up a bit over a few months of riding I think.
Posted : 24/04/2021 11:24 am
