Rockshox Domain 302
[Closed] Rockshox Domain 302
4 Users
Hey All,
Got a brand new set of Rockshox Domains, had them about a month.
They only compress about 40MM and are then locked solid, I'd rather if service themself. But does anyone have any clue as what it might be or what I might need to do?
Any help appreciated.
Cheers JJ
Posted : 15/07/2014 1:33 pm
Sounds like too much oil in them. Drop the legs off and do a lowers service.
Posted : 15/07/2014 3:03 pm
Cheers ...
Should have added they have been working perfectly for a month attaining full travel and then have simply locked at 40MM travel on the last ride.
Posted : 15/07/2014 7:12 pm
Damper oil dropped into into the lowers? I'd have the lowers off and see what comes out, there should be just a small amount of oil in each side (and may be less). And if that doesn't find anything interseting, you can also test the movement of the 2 legs independently to see where your issue is, and go on from there.
Posted : 15/07/2014 7:18 pm
 LoCo
Rebounbd sealhead seal having 'blown' is most likely cause, if new return to place of purchase for warranty repair by Fishers (uk Sram/Rockshox warranty centre)
Posted : 15/07/2014 7:33 pm
Thanks Loco - sounds likely problem. They are new but bought from Taiwan, so guessing that will have to service myself!
Posted : 16/07/2014 10:24 pm
Hi Loco,
Looks like I jumped the gun would I need a new full rebound kit or would a new seal suffice, if the seal any ideas where I could get a seal from?
Help appreciated.
JJ
Posted : 16/07/2014 10:42 pm
