Rockshox damper rem...
[Closed] Rockshox damper removal
3 Users
If i was to pick up a Rockshox sektor chassis that was had a TK damper would i be able to just remove the damper and fit my MOCO damper back in?
Both forks are 2012 140mm solo air forks.
Posted : 23/09/2013 2:54 pm
I did a Sektor R to Sektor RL change the other day, apart from an extra 5ml of oil (I drained the oil and refilled it fresh while I was doing it) there was nothing that needed changing. Suspect TK is pretty much the same, but you're removing a damper as opposed to a plastic cap.
Posted : 23/09/2013 3:01 pm
Ok great thanks.
Posted : 23/09/2013 3:07 pm
No, it'll be a disaster, you need some new Rev RCT3s instead.
Posted : 23/09/2013 3:30 pm
Daveh, did you get my email mate?
Posted : 23/09/2013 3:38 pm
Yeah 😉
Posted : 23/09/2013 4:26 pm
