Rockshox axle help
Rockshox axle help
5 Users
Help please.
I've got an old set of jump forks that require a new axle. They’re 20mm x 110mm qr thru axle.  I’m struggling to get my head around what I can source to make them work.  Anyone shed some light on my predicament, send a link to an axle or go spare part fishing in their sheds for that part that will work?
Thanks
tim
Rockshox axle
Posted : 23/12/2024 11:25 am
Well that didn’t work :0(
Posted : 23/12/2024 11:28 am
Posted : 23/12/2024 11:31 am
IMG_20241223_121912139
Posted : 23/12/2024 12:22 pm
What fork, maybe an Argyle?
Tftuned have this offering but not sure the DJ forks were 35mm. https://www.tftuned.com/front-maxle-lite-mtb-20x110-length-165mm-35mm40mm-chassis-2011-2016/p3449
Posted : 23/12/2024 12:23 pm
Any use to you?
Think it was out of a Revelation.
It's 20mm whatever it came out of.
Posted : 23/12/2024 12:30 pm
Ok, it’s a coil fork without stickers.  Could be an Argyle.  QR optional but my simple head says that if it looks like my photo then it’s more likely to work :0)
stu- that looks promising.  Is it surplus to your requirements? DM coming if I can get the messaging thing to play nicely.
Posted : 23/12/2024 12:32 pm
Seen as it was at the bottom of a load of old bits I think it's safe to say I no longer need it. 🙂
Posted : 23/12/2024 12:35 pm
Fork pics.
Thanks for all the help. I had an idea that a Boxxer axle might work.
Posted : 23/12/2024 12:48 pm
I had an original pike, same lowers as an argyle and a maxle lite from a 20mm sektor worked, there were 2 versions of the older maxle with the tapered nut on the end and one isn't compatible without adding a washer big enough to slide over the shoulder, I don't think the boxxer axle will work as it doesn't have the shoulder section for the right leg of the lowers that's fatter than 20mm.
Posted : 23/12/2024 3:16 pm
