I have a 2022 boost 650b Lyric that is 160mm that should really be at 150mm
I have an older (will check serial no tonight) 100x15, 29er Pike that is 130mm and could happily be run at 140mm.
It seems I have the requisite parts as I think a 29er air spring is 20mm longer for given travel... or at least it was when these forks were made.
Can someone tell me if I'm right or wrong before I'm left sat crying in a pool of suspension oil having rendered both my bikes unridable?
Wrong, the Lyrik/Yari air springs are not compatible with the Pike/Revelation ones due to having a larger diameter chassis.
