Rocket Ron Evo/Perf...
[Closed] Rocket Ron Evo/Performance - difference?
3 Users
Hi
Can anyone tell me the difference between these two tyres other than price? Or are they the same tyre?! Help!
Posted : 01/02/2012 12:44 pm
Definitely not the same. Different carcass and compound, the only common thing is the tread pattern.
Evos are lighter, grippier, more expensive, fragile and wear quicker.
Performance are the opposite.
I use the Evos personally.
Posted : 01/02/2012 1:02 pm
As above, the performance tyre is slightly heavier at 500g, but at around £15 a tyre they are a bargin.
I use the Performance personally because I run tubeless & the side walls are more robust than Evo's.
On the road there a bit noisy due to the harder compound.
I belive there is now a Pacestar tubeless ready which is lighter than the full on UST.
Posted : 01/02/2012 1:08 pm
Aye, the 2011 Evos are all tubeless ready, no heavier than the old Triple Nano Evos, but designed to work tubeless. Personally I found the older tyres easier - they weren't as tight!
Posted : 01/02/2012 1:23 pm
Thanks guys
Think I will try Evos first and see how I go...
Posted : 01/02/2012 10:20 pm
