I have been searching around for ages and can't see where you can buy this tool from. Bleed kits and IFP tools are easy to get hold of but not the oil height tool.
See page 24 of this to see what I am talking about
Anyone know where to buy one from?
They're in stock at Alltricks.
Cheers, any chance of a link as I can't find it on their site?
It's basically just a tube for pushing the IFP (If I remember right) down into the post. Another bit of tubing with the right Id, od and length marking *should* do the job I think. It you'd like to try it i can measure mine
Here's the 3 tools I used to do mine:
Cheers Stumpy, but those tools except for the ISP Height tool are for the standard Reverb not the stealth. I think what swanny is describing will work.
I take it back, I misunderstood what you meant- I was talking about the IFP height tool. I've not done a stealth post yet.
Have you done it before? One problem I had was getting the main collar off (it'd been fitted a long time) as my vice wasn't up to the task- ended up clamping it back in the bike, worked a treat.
Let us know how it goes!
I have done it before but I just missed out the step described. It seemed to work fine but is needing done again after only a couple of months so want to do it again properly. It was very easy when using the PDF I have linked above.
