Gents, I'm looking at getting some 2012 Reba RL's from [url= http://www.merlincycles.com/bike-shop/frame-forks/forks-shocks/rockshox-suspension-forks/2012-rockshox-reba-rl-forks-remote-lockout.html ]merlin:[/url]
They are selling 100mm and 120mm. I was under the impression that these forks have spacers in them where you can set the travel from 80-120mm by removing or adding the spacers, I have another set of old Rebas where you can do this.
Does anyone know if this can still be done on the new forks?
Thank you.
I've got the exact same forks as those in the link and you'll see they've got sag markings on the right leg, 80mm, 100mm and on mine you can see that it carries on past the seal to presumably 120mm, so i'd say that its almost 100% likely that yes there is a spacer fitted for 100mm and adding/removing will alter the travel.
HTH but the only way you'll no for sure is to try, as there may be some OEM ones around that are fixed, however i'd imagine they wouldnt have the different travel sag settings on the stanchion as they wouldnt be needed.
