Rock Shox RC2DH/Fro...
[Closed] Rock Shox RC2DH/Front wheel washing out
5 Users
Curious - friend got some new forks, Totems with RC2 damper. He washed out his front wheel a few times on them, I had a go and found the same.
I know it;s a bit of a how long is a piece of string question, but what kind of compression/rebound settings are people using on theit Totems (or RC2DH Boxxers/Lyriks)? Think that might be a factor.
Posted : 27/02/2013 12:45 pm
Damping settings are dependant on lots of other factors - preload, geometry, weight distribution and riding style.
Is this a new problem on an old bike? What forks was he using before? How does the A2C vary?
Posted : 27/02/2013 12:50 pm
 LoCo
Have look at the setup guide, http://locotuning.co.uk/tech-info.html
it maybe rebound it too quick or slow, and or low speed comp settings.
Posted : 27/02/2013 12:51 pm
He had Domains, setup identical in terms of bars, stem, tyres, etc, same med spring, and negligible difference in A2C, so apart form the forks probably being a bit plusher and newer, the damping is the main difference.
Posted : 27/02/2013 12:53 pm
Hi, I had the same problem on my Boxxer.
Turned off all the compression and used as little rebound as I could get away with and things improved dramatically.
I did have a slightly too firm spring though, so if he has correct weight perhaps turn all the compression off and add a click or two as required?
Posted : 27/02/2013 12:56 pm
 hora
I had the same, a combination of bar rotation and stack height helped. Plus I'm shit on a bike. So the first two adjustments helped me stay more on the bike.
Posted : 27/02/2013 1:05 pm
