Rock Shox Pike Serv...
[Closed] Rock Shox Pike Service Question
3 Users
Just taken my rockshox pikes apart and removed oil and wiper seals. Notice that in both lower legs at the bottom there is a circular rubber/plastic disc with a hole in the middle that the metal from the upper goes through, the questions i have are:
1. What is it?
2. What does it do?
3. Why is one of mine straight and the other on slightly curved/bent?
Posted : 14/01/2010 9:17 pm
Will it also need replacing?
Posted : 14/01/2010 9:47 pm
bottom out bumpers.
thread them back onto the prongy bits at the bottom of the stanchions before you re-install them.
Posted : 14/01/2010 10:39 pm
Why was one of them slightly bent?
Posted : 15/01/2010 2:21 pm
Might have happened coming out. Nothing to worry about. I personally prefer to poke them back into the lowers, checking they're flat against the bottom before installing stanchions.
I think they also enable tightening of the damper rod bolt. The one time I forgot to put them back in, I couldn't tighten the bolt under the rebound knob because the damper rod was just spinning round with it.
Posted : 15/01/2010 3:13 pm
My worry was that they had been running with one not properly inserted althugh dont think this is the case.
Posted : 15/01/2010 4:59 pm
