To add to a very long list of problems with my Lyrik 2 Step Air fork (now on 3rd one under warranty) the floodgate lock out adjusted at the top of the right fork leg keeps popping up whilst riding locking the fork out.
Anyone else have this problem and any easy fix? All I can think of now is to duck tape the adjsuter down !!
It'll be a mis aligned or missing bearing that normally sits in a recess within the Mission Control System, it's held in place by a "C" clip. Easy enough to sort out, remove the Mission Control damper and you'll see the "C" clip. Check to see if the bearing is there, if not that'll be your problem.
Have a look here (Page 39): -
[url= http://www.sram.com/_media/techdocs/2008%20RockShox%20Technical%20Manual%20web.pdf ]Lyrik Manual[/url]
