rock shox lyrik 201...
[Closed] rock shox lyrik 2011 r 160mm to 170mm + seals question
2 Users
can anyone tell me if they have done this ?
i have seen some say that its a 10mm spacer in the air side that needs removed? if so someone got a guide?
if not
others say you need to fit the mission control and new rebound rod...
also what are the best seals to use?
could anyone shed some light on this matter?
thanks
calum
Posted : 09/10/2013 10:05 pm
anyone?
Posted : 10/10/2013 8:30 pm
If it's possible for your forks, then this is how. RS changed their internal recently though, so this method might not work any more. I think 2011 is OK, but not certain.
http://www.bikeradar.com/gear/article/workshop-how-to-adjust-travel-on-a-rockshox-trail-fork--26840/
Posted : 10/10/2013 8:34 pm
that looks a great writeup / guide!
yeah from what i read it seems 2012 they changed but apartently before that there is a 10mm spacer in the 160mm solo air forks! so hoping to get 170mm to match the 170mm on the rear of my reign x
Posted : 10/10/2013 8:39 pm
