Rock Shox Damper Sw...
[Closed] Rock Shox Damper Swaps
3 Users
I have a 2018 base spec 27.5 Lyrik with a charger damper that only has low speed compression adjustment and a 2019 29" Yari and I'm not fully satisfied with either.
Is it possible and worthwhile to swap the original low spec Charger damper into the Yari to replace the Motion Control? (I would get a 2.1 for the Lyrik) I have the upgraded Debonair shafts on the way already so both will be getting stripped down to be worked on soon.
Posted : 30/04/2020 5:17 pm
I did this with Pike and Revelation and it worked out OK, but I can't tell the difference between the RC and the RCT3. Shockwiz tells me to run the RCT3 fully open for compression damping 🧐
Posted : 30/04/2020 5:41 pm
Yes thats something you can do easily.
Posted : 30/04/2020 5:42 pm
