Need to change the air shaft in my 2016 27.5 pikes. 150mm required. It’s already had the damper upgrade. Worth spending the extra fiver for This one ?
More importantly will it fit? Not sure the Pike chassis has changed much in the last couple of years, but before I make that assumption, does someone have real world experience? Ta.
Yes its worth doing for sure, probably more so than the damper. However you need the version for 2015-17 pikes.
Thanks Ben. I just realised that having done some actual research rather than guessing 🙂 I’ll ask Jake at Sprung to get me one…. probably safest.
Update: Sourced one (from TFT in the end). I was tempted by those Fox 36s on the PSA but felt £42 was a somewhat more appropriate outlay considering I actually had a set of forks already!
