Rock show lyrik
[Closed] Rock show lyrik
4 Users
Hi i have some rock shox lyric set up at 4,4 and a rebound of 11 which they recommend, i have found that after compression they dont go back to the full length which u have to lift the front wheel to get, anyone know why?
The forks are brand new.
Posted : 07/12/2011 9:19 pm
Stiction in the new seals? They may not have broken in yet.
Posted : 07/12/2011 9:25 pm
Sag. Perfectly normal - if it's <20mm
Posted : 07/12/2011 10:36 pm
even if ur not on the bike?
Posted : 08/12/2011 9:29 pm
No, if you're not on the bike the forks should extend to their full travel. I'd say it's probably due to stiction caused by new seals and should free up after a few rides.
Posted : 08/12/2011 10:01 pm
arr right cheers well ill be giving it a few good rides soon so will see after that
Posted : 08/12/2011 10:21 pm
My Lyriks do this exact same thing, I'm only talking about 3-4mm max but if you lift the front of the bike they will extend by this amount. Also the coil U-turn ones seem to differ in max fork travel from fork to fork - i.e. some get the full, in my case 160mm, while some get a little more and some a little less. I sent mine to TF with this in mind and was expecting them to say there was something wrong with them but they said the fork was sweet as a nut, give it the normal service and sent em back. Still get the same thing now with lifting the front of the bike up but don't worry about it.
Posted : 08/12/2011 11:12 pm
oh ok i just thought it was a little abnormal :p
Posted : 08/12/2011 11:42 pm
