I have a monarch plus rc3 debonair. The issue I have is that the shock seems to resist in the first 3mm of the stroke (what I would expect) then the next 10mm seems to suddenly lose lots of resistance and drops to the 20% mark before having resistance again. I've bleed the IFP reservoir didn't seem to sort it. Anyone had similar issues? My mates with the same shock don't have the same thing.
I'll try a full strip down to see if anything is lose.
Isn't it just your 2 air chambers equalising? Hence pretty normal.
Sounds a lot like you have an air gap in the damper. Get your lbs to send it to Fishers for a warranty repair (depending how old it is etc)
Cheers i'm going to have it looked at so should hopefully will get it sorted.
