Roadie Size Help?
[Closed] Roadie Size Help?
11 Users
I'm looking at buying a first road bike. I'm 6ft and ride a large stumpy for XC and a medium Glory for DH which I find a little short. The stumpy is a 19" and i'm looking at a large scott speedster. The bike is 56cm which I think would be perfect but a mate has suggested I might need a 58cm. What do the STW Roadies think?
Posted : 22/02/2013 7:00 pm
Fit is crucial on a road bike - you spend a long time sat/ceased in pretty much the same position. Getting it wrong can be painful and expensive.
Only way to see is to sit on one and try it out - and sizes vary by manufacturer and geommetry - I've had road bikes in 48, 52 and 54 sizes over the years.
Posted : 22/02/2013 7:04 pm
I think you should go to a good shop and not rely on anecdotal sizing evidence from people who are not the same proportions and flexibility as yourself.
Posted : 22/02/2013 7:09 pm
I think you'll be ok on either, my eldest has outgrown his 54 speeder he's 6ft....as said above, best to try them..
Posted : 22/02/2013 7:16 pm
58 comfort fit, 56 a race fit, a bit more bum in air.
Posted : 22/02/2013 7:19 pm
I used the [url= http://www.competitivecyclist.com/za/CCY?PAGE=FIT_CALCULATOR_INTRO ]Competitive Cyclist[/url] fit calculator and it was pretty much spot on for me.
Posted : 22/02/2013 7:21 pm
This.
top tube length is important for fit, not seat tube (htough its how manufacturers "rate" fraem sizes). My 52cm Lapierre has a (slightly) longer TT than my 54cm Orbea, which has the same as the 55cm Bianchi I borrowed (all 550cm effective TTs).
Posted : 22/02/2013 9:19 pm
57cm?
Posted : 22/02/2013 9:23 pm
As above, 58cm will have a longer top tube,higher handlebars and a reasonably relaxed fit. 56cm will need a longer stem for the same reach (bottom bracket to handlebars) with more weight over the front. For a first roadbike, go with the 58cm. You may,however find that you want a 57cm. In which case another brand may be a better fit.
Posted : 22/02/2013 9:52 pm
56 or 58. both will be ok.
2cms is the width of your thumb, and really wont make much difference to an average person
fwiw i would go for a 56 TT frame iiwy
Posted : 22/02/2013 9:59 pm
2cm will make a difference, that's why stems come in different lengths and I swapped from a 120 to a 100 on one bike. Do you wear shoes a size too big as well?
Posted : 22/02/2013 10:04 pm
Of course seat tube is important im 6ft 4 if I rode a small frame the bars would be way to low my 24 to 25 inch frames have about 9 inches of seat post out and long stems I would look like I had outgrown anything smaller
Posted : 22/02/2013 10:08 pm
