Roadie Gears 10sp v...
[Closed] Roadie Gears 10sp vs 9sp, compacts and failing to man up
11 Users
 trb
So after 6 years of manning up with a standard 53/39 chainset and gurning up the hills on my road bike, I find myself admitting defeat and looking for a compact.
Simple question before I hit the buy button, If I buy a Tiagra or 105 compact 10 sp crank set, is it compatable with my 9 speed cassette and chain?
Posted : 20/09/2012 2:16 pm
Yes. You'll end up with a chain that's a bit too long, but if you couldn't be arsed looking for your chain tool, like me, and left it, after a bit you wouldn't notice it.
Posted : 20/09/2012 2:22 pm
 trb
lovely job. Spinning up hills in the saddle here we come!
Posted : 20/09/2012 2:44 pm
you'll just gurn at a lower speed
Posted : 20/09/2012 2:47 pm
I have a compact, and I don't like the massive jump between the front rings.
Posted : 20/09/2012 3:22 pm
 mboy
What he said
You'll only be dropping your bottom gear by about 15% or thereabouts, it's not going to be massive. It'll make it a bit easier, but if you actually want to spin up hills you'll be looking at a triple up front with a mountain bike cassette and rear mech!
Posted : 20/09/2012 3:24 pm
What scaredypants said.
Posted : 20/09/2012 3:28 pm
I have a compact, and I *do* like the massive jump between front rings.
...if I only want a small jump I use the rear shifter 😉
Posted : 20/09/2012 3:35 pm
Likewise - I've kinda solved that by going compact, but with 50/38 rings and 12/25 cassette. It's a pretty even spread across the rings/block. No, bottom gear isn't massively low (could be solved with a 37 or 36 ring) but for me, just bimbling along to work, it was more about smoothing the hills a little more whilst swapping the massive top gears of 53/11 for a more even spread.
Posted : 20/09/2012 3:39 pm
 trb
That's cool, I only really want 1 more lower gear anyway, and I already have a 11-27 cassette, I'm going to have to stop blaming my kit and start balming myself if that isn't low enough.
My riding buddy has just gone all Strava on me so we're currently trying to beat 95th on the local climb.
Yeah I know, but putting slicks on my MTB would be really admitting defeat.
Posted : 20/09/2012 4:00 pm
The jump between rings necessitates moving 2 or 3 gears at the back at the same time. I suppose if your pedalling style is particularly rough it wouldn't bother you too much.
Good idea. When I've got a bit more wear out the rings, I plan to change to 48/36 with an 11-26 block. 48/11 is about the same as 53/12, so plenty big enough.
Yep, like my mountain bike. The way I solve this is by moving 2 or 3 gears at the back at the same time.
Dunno about that...but I suppose if you're chopping and changing between front rings all the time it *would* bother you...
Posted : 20/09/2012 4:15 pm
I have a Tiagra triple chainset - it's great!
Good spread of gears and no big gaps.
....I'll get my coat!
Posted : 20/09/2012 4:31 pm
Alternatively, a triple on an MTB and standard double on a road bike means no need to change at the back. But well done for so cleverly solving a problem that doesn't need to exist.
If there isn't a problem, as you suggest, then why would repeated front changes be an issue?
Posted : 20/09/2012 4:37 pm
 Haze
Changed from 50/34 and 12-27 to 50/36 with 11-23 on the back, things feel a bit smoother now.
Posted : 20/09/2012 5:05 pm
You can use a SRAM chainset if you want, just think they are a better offering at that level.
Posted : 20/09/2012 5:31 pm
