Road Wheels ~ Scrib...
[Closed] Road Wheels ~ Scribe, Prime, DT or something else?
38 Users
 P20
Looking for some road wheels to go on my new bike when it arrives. I’m not that bothered by deep section aero as I’m unlikely to be going fast enough to benefit! I’m more interested in the wheels being light.
So I’m looking at,
https://www.chainreactioncycles.com/prime-attaquer-disc-wheelset-tubeless-bundle/rp-prod198696
Or
https://scribecycling.co.uk/collections/alloy-disc-brake/products/scribe-race-d
or
https://www.merlincycles.com/dt-swiss-pr1400-dicut-21-disc-clincher-road-wheels-700c-204813.html
the prime and the scribe look very similar spec and I believe the scribe team used to design prime wheels, so no huge surprise. Both sets look good value.
The lure of the DT hubs is strong, but it’s a huge jump and not one I feel I can justify.
I will happily run tubes on the road, but may try tubeless.
I realise I haven’t listed Hunt which would be an obvious candidate but don’t feel they offer anything over the Scribe/Prime
any thoughts appreciated
Posted : 23/02/2021 4:25 pm
I have some Prime Race on gravel bike, they've been ok, needed a bearing replacement after a year or so of all weather use. My other half has some superstar components wheels that I got with a 50% discount code which were crazy value
Posted : 23/02/2021 4:46 pm
I looked at Scribe recently, really good weight to cost ratio was i was put off by the loud noise of the freewheel. Search it on Youtube, its worth checking before you buy if that sort of thing may bother you.
I upgraded my DT-Swiss DiCut RR21 to some Hunt50 carbon hoops.
The DT Swiss are lovely and marginally lighter than the hunts but i wanted some carbon rims as I'm a total road ponce. It was a very close between scribe and hunt to be fair....yes they are very loud and they are slightly faster on the flat but the main thing is they look badass.
The DT Swiss are now sat in wheel bags doing bugger all, I'm open to selling them if want to go down that route.
Posted : 23/02/2021 4:49 pm
I thought this when I upgraded the wheels on my road bike and ended up on some carbon Reynolds ARX DB 41 (which are 41mm deep as the name suggests), up from some alloy DT Swiss jobbies. The original DT Swiss wheels weren't that light, but good lord did the new wheels make a huge difference. I reckon I get 3 or 4 'free' km/h out of them. So I guess what I'm saying is don't underestimate the difference that a mildly deep aero wheel can make even at 'regular' rather than pro speeds.
Posted : 23/02/2021 5:00 pm
 P20
Noise doesn’t bother me. I run King on the hardtail and I think the loudest was Royce BITD.
@mrchrispy I could be interested depending on how much you want/spec that I’m looking for to fit the new bike
Posted : 23/02/2021 5:02 pm
 P20
@soundninjauk
the thing I dislike most about the deeper rims is the effect crosswinds have
Posted : 23/02/2021 5:04 pm
Check out Pacenti, their hubs are Bitex, so the same as Scribe (and probably also Hunt/Prime) but I *think* the rims are very slightly nicer (assuming Scribe/Hunt etc. use Kinlin rims, the Pacentis are a tiny bit lighter/nicer finished).
I'm a bit of a fan boy but have a horrible feeling it's mostly down to the Italian sounding name and fancy stickers...
https://pacenticycledesign.co.uk/collections/aluminium-wheels-road/products/forza-wheelset-centre-lock-disc-brake-700c
Edit: new ones don't have quite as fancy stickers it seems...
Posted : 23/02/2021 5:08 pm
I have a set of Scribe 40's on the road bike. Compared to the stock DT wheels that came on the bike there is an obvious difference in the stifness feeling of the wheel. Its really noticable when accelerating out a corner. Despite this they do not feel uncomfortable on the rough roads which is nice. The seam very well made and are easily serviceable. One of my wheels went wrong after less than 2 weeks while I was on holiday in France. Scribe posted out a replacement complete with tyre on a next day delivery. They were surprised by the fault and further googling on my part has not shown up any other reliability issues. The replacement wheel has been faultless too.
The only negative is the noise of the freehub, it really is loud. Thankfully you don't do much freewheeling on a roadie!
Pretty sure Scribe Hubs are not Bitex, they are certainly different from hunt etc
Posted : 23/02/2021 5:11 pm
 P20
I’ve got Pacenti rims on the gravel bike, but they have required a bit of attention to keep them straight, but I guess that could be the build. That Pacenti set are giving away 200grams though to the Scribe/Prime.
I thought hunt used novatec?
Posted : 23/02/2021 5:14 pm
I had some prime wheels on my road bike. They were great, ran true for 3 years, raced, ridden across the alps etc.
Sadly they cracked around a couple of the spoke holes. Front one still holds up my turbo bike. That said I'd buy them again. I gave them some stick and the one's I got were at the cheaper end.
To add to your list I'd have a look at justridingalong. I had a set of their wheels on my CX bike. 5 seasons, 3 goes at the 3 peaks and I didn't touch them!
Also Cero, they used to be popular and I heard good things. Likely similar in quality to Prime - just rebadged far east stuff (which i'd be happy with). Probably kinlin rims on novatech hubs.
Posted : 23/02/2021 5:15 pm
Have you looked at JRA?
I’m currently tempted to get some 35/50 deep carbon wheels, so not really looking at the same stuff but JRA looked a good option there.
Edit: I’m obviously incapable of reading the post above properly.
Posted : 23/02/2021 5:27 pm
 P20
Just to add some context to this thread. I’ve just sold my Colnago complete with it’s original Ksyriums on it at 18yrs old! Original bearings etc. Would consider the latest version but they’re heavier than the options I’m looking at.
Posted : 23/02/2021 5:29 pm
To add to your list I’d have a look at justridingalong.
JustRidingAlong MAP wheels look awesome for the money, can build very light (especially with the CX-Ray spoke upgrade) and fully customisable.
Was about to hit the button on a set but gave in to pride/vanity/cheapness and decided to build my own wheels instead.
I think that must have been the build, I built a set up 28 spoke, 2 cross, as tense as the rims could handle, and they didn't need any attention in a year of clumsy gravel chundering until I dissolved the front rim in 3 months muddy CX use 😣
I agree that their builds all seem relatively unspectacular at close to 1650g, I think it's just the spoke count etc. that causes it, the rims were the lightest aluminium rims I could find aftermarket (well, for the width and depth anyway).
Posted : 23/02/2021 5:46 pm
I'm wary of lightweight alloy wheels that use standard (low count) spokes and hubs, having used sets in the past that just weren't stiff enough. They feel vague when accelerating and when riding over rough roads downhill.
Light Bicycle or Far Sports should be able to build you something with lowish profile carbon rims, that'll be stiff and light (circa 1300g). They should come in at the top end of your budget.
Posted : 23/02/2021 6:27 pm
@P20
Yeah fair enough. I’ve found the trade off to be worth it in my riding but of course YMMV.
Posted : 23/02/2021 6:30 pm
I have roval slx24 which have DT internals and I run them tubeless. Been perfect for over 10K miles
Posted : 23/02/2021 7:13 pm
JRA mahi mahis, good price, decent weight and few build options so you can make them pretty.
Posted : 23/02/2021 7:38 pm
 Haze
Something from Lightbicycle maybe?
Just got 56mm carbon rims (you can go shallower/lighter) with DT Swiss 240 EXP hubs built up with CX Ray
About £850 delivered, choice of hubs or cheaper spokes etc
Posted : 23/02/2021 7:49 pm
I'm after a loosely similar thing (sorry for slight hijack) and so these options have piqued my interest but raise a question...
Spoke count. Talking to a respected wheel builder he says go 28/28. Would only go down to 24 for really quite light riders, <c.70kg. and the problems are from braking force, implying front needs as many as rear. Yet many options, including all the above, have much lower spoke counts and often without deeper section or carbon rims so I don't think there's a mitigation on stiffness.
What say you folks on this?
I'm hovering over the go button on hand built 28/28 20mm internal width rims (Hydra, Aileron or Kinlin) but on Hope hubs for better sealing, accepting a weight and cost penalty there. From c.£450 but a bit more for black spokes/nipples.
Posted : 23/02/2021 8:28 pm
Carbon rims do make a lot of sense for a disc build.
On my winter bike I have some wide, 30mm deep Farsports rims with DT Swiss 350s and 28/28 CX Rays, brass nipples. From memory they came in about £620 including delivery and pre paid import tax. About 1450g for the set.
You can go a bit lighter for a summer build if you spec Bitex or similar and alu nipples.
One pair of scribe 40d and one pair of light bicycle 56mm falcon on novatecs here. Both on cx rays, both tubeless.
The scribes are noisy but filling with grease does help. The novatec hubs have an easy life (Aussie weather and best bike) so I wasn’t too worried about bearing sealing.
Both sets are light and have been reliable so far. No complaints with either.
Posted : 23/02/2021 8:39 pm
I've got 2 sets of Scribes, some 365 Alu for winter and a set of Aero 50 Carbon for summer. Been really pleased with the performance and service from Scribe so far. Still nice and true even after shite roads and the bearings are still smooth. Bought the Carbon's to replace my campag Bora's with ceramic bearings that barely lasted 3 wet Sportives.
Posted : 23/02/2021 9:29 pm
 P20
Those JRA look good.
having read the road.cc review and the comments aboveI think I’m leaning towards the scribes
Posted : 23/02/2021 9:50 pm
I'd be wary of 21 spokes on a front disc brake wheel, 24+ is considered the norm iirc.
Posted : 23/02/2021 9:55 pm
I had some prime Pro disc wheels, 1450g ish. They were quite flexy and bearings wore out quickly. Not sure I'd buy them again. As above I'd prob get more spokes, 32 i think, even it means a custom build. Then again im not so fussed about weight these days.
Posted : 23/02/2021 10:08 pm
I've got a set of Pacenti rims built up on Hope hubs by my LBS on my gravel bike.
I'm a 100KG talentless oaf, and have had minimal issues over the last couple of years (1 broken spoke i think) so they do build into reliable wheels.
I have a second set of Pacenti rim-braked wheels on my roadie which have been similarly reliable - and a massive improvement over the H Plus Son Architype rims they replaced - which were total rubbish.
I'd rather buy hand built wheels from a trusted/reliable local source, which need not be more expensive than mass-produced stuff on-line, but everyone's experiences and needs are different.
Posted : 23/02/2021 10:26 pm
Strada All Season Disc wheels linky
DT rims, Miche hubs with upgraded seals and bearings, handbuilt to a very high standard.
I've got a set of these with the slightly wider 22mm DT rim and bladed spokes and they're superb, as are all of the wheelsets Strada have built me over the years. Also have some Forzas on Novatec hubs, which are nice but the DT/Miche build "feels" better.
Posted : 24/02/2021 9:07 am
I'd also be "concerned" about the Scribes. I don't understand the use of radial or 1x spoking on a disc wheel. In their info, they suggest that
"When you apply braking on disc brakes, wheel speed is slowed by applying force only on the disc side of the wheel." **
So, er, the hub flanges aren't connected? I'd love to understand more if someone can educate me.
**perhaps for their wheel build this statement is true *because* they use radial spoking. Rather than the statement being true, thereby *allowing* the use of radial spoking?
Posted : 24/02/2021 9:56 am
 P20
Pretty sure Roval and others do the same with the radial lacing. Having read a bit more about the JRA Map wheels I’m swinging towards them.
Posted : 24/02/2021 10:26 am
Original Ksyrium wheels (non disc obvs) were radial in the drive side. It's daft IMO but it seems to work. Braking forces are lower at the rear and on the front wheel the disc side spokes are in higher tension.
Posted : 24/02/2021 11:01 am
On the spoke counts for disk braked wheels - yes, definitely at least 24 spokes.
I did a bit of static force analysis (*) a while back and stuck the formulae in a spreadsheet - you get surprisingly large changes in spoke tension under extreme braking. Depending on the hub flange height and number of spokes I'd also prefer 3x lacing vs 2x, which reduces spoke tension change by 10% or so.
And yes, agree @mcbyker , unless the hub shell is twisting massively the torque will be transmitted on both drive and none-drive. One thing is certain, on any wheel the radially laced side is doing nothing under drive or braking loads. I reckon disk wheels one side radially laced are quite likely to be seeing half the drive side spokes slack and conversely the other half doubled in tension under extreme braking loads. Not a pleasant thought, not good for the rim bed spoke holes or for the wheel trueness if those slack spokes decide to unwind a bit.
(*) this is simple geometry really, the only remotely tricky bit is working out the formula for perpendicular distance of the spoke from the hub centre with varying spoke crossings. The rest is just taking moments and estimating the max braking force at the contact patch.
Interesting, you think the spokes "pushing" under braking are clotheslining if one side is radial?
Posted : 24/02/2021 12:02 pm
 jwt
Prime wheels - have a set of cheap disc wheels that lasted three winters before needing new bearings. The latest set of bearings haven't lasted that long since replacement, but they were cheap.
Scribe pace wheels - about three years , been great, done the Fred, couple of tour de yorkshire,lots of lakes rides & never missed a beat, and more 'comfortable' than the Hunts they replaced at a similar weight.
Scribe carbon 3850's on the 'best' bike that I've made more of an effort to use last year, transformed the ride from the aforementioned Hunts, (but apples and oranges as they were race aero I think?) fine in crosswinds and very light.
If I could find an excuse and the money for some Scribe 5068's i would get some.
Alan at scribe is very approachable and honest.
Posted : 24/02/2021 1:39 pm
 P20
https://cyclingtips.com/2021/02/scribe-aero-wide-42-disc-brake-road-wheelset-review/
different wheels but front lacing is inconsistent, but the negative seem to stop there for the pattern.
for me, I’m still thinking jra
Posted : 24/02/2021 1:44 pm
 P20
JRA Map Superlights ordered! 😃
Thank you all
Posted : 24/02/2021 5:45 pm
 P20
So the JRA MAP super lights arrived and they are lovely. 1380grams saving (with new tyres) 1400grams on the existing wheels! The Bitex hubs are definitely a step up from Novatec. Will hopefully get to ride them next week
Posted : 12/03/2021 1:13 pm
Nice! And good to see tyre logo and valve alignment.
Posted : 12/03/2021 6:51 pm
Very nice. Love my MAPs.
Posted : 12/03/2021 6:56 pm
 Kuco
Does anyone use Zipp wheels?
Posted : 12/03/2021 8:12 pm
 P20
@shortbread_fanylion
Ive been here long enough to this properly!
Posted : 13/03/2021 1:16 am
Hi folks, Alan here from Scribe. I jumped onto the thread to highlight an inaccuracy, it has been stated in one of the posts that Scribe use Bitex hubs, this couldn’t be further from the truth. Scribe’s hubs, much like our rims, have been designed in-house from the ground up. This allows us to bring unique products to the market but only after a rigorous testing program based in both the UK and Ireland. The whole philosophy behind Scribe is to offer riders the best wheels possible and for the level of specification and technology in our wheels, you get a seriously high-performing wheelset for the money. If anyone would like to know more about our products or the Scribe brand in general, we are always available via email or chat. Thanks folks.
Posted : 14/04/2021 9:41 am
Can you confirm who actually makes your hubs for you Alan?
Posted : 14/04/2021 9:56 am
 kern
They are hardly going to give you that information FFS, would Rapha, Yeti or any other brand for that matter? Come on man, you could be an industry insider, sure why not ask to see their full business portfolio.
Posted : 14/04/2021 4:10 pm
I have some scribe carbon disc wheels. They are fantastic. They remind me of some Rose RS1400 wheels I had a few years ago that I had forever regretted selling. Personally I much prefer them to equivalent Hunts
Posted : 14/04/2021 6:02 pm
Curto80, just wondering what Hunts you have tested the Rose and Scribe wheels against.
I’ve ridden pretty much every major brand of wheel and being brutally honest, if on a blind test I would have no idea what I was on.
I liked Zipp 303’s firecrest because I found them aesthetically pleasing. I rated my Bontrager Aeolus 5’s as they seemed fast. But the Aeolus were no different than my Edco 50mm wheels or my Hunt 50mm wheels. In terms of fast (aero) wheels, I preferred the Edco clinchers as they were easy to change tyres on. Fastest wheel I’ve had was a Reynolds 65mm set, but an absolute pig to change the tyre on. I’d race on the Reynolds on Crit circuits where a flat is very unlikely, but not for Road Races. They weren’t fast because of some sorcery used by Reynolds, they were fast because they were deep, with an aero tyre profile and a fast race tyre.
Durability wise, Vision Metron 40’s in my experience are the only carbon wheel that hasn’t been great, but then that’s used for more wet weather rides. Been sent back to the manufacturer twice.
Probably the biggest difference was Bontrager Aeolus tubulars. Very light wheel so made the bike feel lively, about 1200 grams and also running a light race tubular. Probably a couple of seconds faster than a heavier wheel up a 40 minute climb, but still felt lively.
I currently have Bontrager RSL 37mm wheels, Hunt Aerodynamisist, Bontrager Aeolus Pro 37mm, and there is so little difference between the wheels it’s hard to tell them apart.
I’d absolutely purchase Scribe wheels, because any performance difference between them and my £2k wheels is going to be pretty much negligible. So for the price it’s a good deal, but I wouldn’t see them being any “better” than my Hunt wheels or my old Zipp 303’s.
Posted : 15/04/2021 11:51 am
Interesting that my reply quoting the 'how to make your own Chinese wheel company' YouTube classic was deleted.
Does a mod own scribe?
Posted : 16/04/2021 3:01 pm
A post from earlier this afternoon from a new forum member singing the praises of the Scribes has also disappeared. All very mysterious.
Posted : 16/04/2021 3:27 pm
 gary
Ah, I wasn't imagining that particularly astroturfy post then 🙂
Posted : 16/04/2021 6:17 pm
It was from a newly joined member and their first post that read like a PR piece.
Posted : 16/04/2021 6:24 pm
That video was funny and interesting.... accurate?
Posted : 17/04/2021 5:48 pm
Scribe wheels get excellent reviews from all the roadie sites / magazines, so they seem to be genuinely good wheels. I'll probably get a pair of their 60mm deep wheels in the next month or so for my Orbea Orca.
Posted : 17/04/2021 7:15 pm
This thread did pique my interest in Scribe wheels and everything out there does seem positive. Leaf spring freehub is an interesting concept too. I was duking it out between zipp and hunt but these are in the mix now too. Very intrigued by the solo post extolling the wheels though, kinda makes me suspicious over all the great things being said on social media.
Posted : 17/04/2021 9:17 pm
My post drawing attention to the gushing praise has also been removed.....
Posted : 18/04/2021 8:24 am
 gary
Easiest to just assume any social media post is a pointless sample - whether paid or just unsupported opinion. There's a decent review here - sounds like a genuinely good set of wheels, with the main issue being how noisy you like your hub https://cyclingtips.com/2021/02/scribe-aero-wide-42-disc-brake-road-wheelset-review/
Posted : 18/04/2021 9:43 am
Most modern carbon wheelsets are good enough that they will review well. You'll never experience the downsides of cheap hubs or spokes in a review timeline - it will take a year or so of use for the misalignment to **** the bearings.
That doesn't mean it's worth paying 2x the price for some other dick to import a set of wheels from Ican or wherever and slap their cool-guy logo on. Just order them yourself.
Posted : 18/04/2021 12:58 pm
