Road wheel for comm...
[Closed] Road wheel for commuting
10 Users
So having had another spoke snap on me this morning, I’m getting frustrated having to replace every 6 weeks now, and making getting home a bit of a nightmare, it’s time for a new rear wheel.
I’m looking for a bit of help choosing. Ideally I’d want straight pull 32 hole, and suitable for 700 x 23 tyres. I’m happy to build it up myself, so I’m really looking for suggestions on hubs and rims. And would ideally be looking for around £150 all in.
If there is anything that I’m happy to drop, it would probably be the straight pul hub.
Opeen to a pair but my front is in reasonable condition but may need a re-rim in the next 6 months or so too.
Many thanks
Posted : 07/11/2017 2:10 pm
 Bez
Drop the straight pull hub. They're a silly idea anyway. Personally I'd just get a mid-range Shimano hub with pretty much any reasonably priced rim and lace it 3x with DT Comps. You could build a pair of perfectly decent commuting wheels on that budget if you shop around for the components; for a rear on its own £100 should be plenty.
Is it for rim brakes? 130mm OLN? 8/9/10, 11, 1 speed…?
Are you breaking drive side or non-drive side spokes, and was it you or someone else that built the current wheel?
Posted : 07/11/2017 2:17 pm
How old are the wheels? The front may look OK but the braking surface on the rim might be close to its limit. If that's the case then look for a deal on a set.
Posted : 07/11/2017 2:20 pm
I'd agree with Bez.
Posted : 07/11/2017 2:23 pm
I had some rigid chrina on tiagra hubs years ago that were rock solid, and weighed about the same, didn't give me a minute of bother for a couple of years though so would second the Shimano hub recommendation.
I bought some Mavic Aksium disc wheels in feb, they've been surprisingly robust for the last 6200 miles. *touches wood!*
Posted : 07/11/2017 2:28 pm
I've got a carbon road bike which I use for commuting and have done for a few years. The original ritchey wheels died after a couple of years use (had the bike since 2011) so I replaced three with Mavic Aksiums.
They aren't particularly light (but I think lighter than the original Ritchey ones), but they aren't showing any signs of dying anytime soon. Never snapped any spokes or shown them any kind of tlc.
Think I paid about £150 for the pair from a cycles.
Posted : 07/11/2017 2:29 pm
 Bez
Tiagra/Open Sport £90 a pair:
https://www.edinburghbicycle.com/pro-build-700c-road-wheel-tiagra-hub-open-sport-rim.html
If you want to roll your own, Google Shopping says a rear Tiagra hub, an Open Sport and a set of Comps will set you back about £60.
Posted : 07/11/2017 2:34 pm
I always forget something. 130mm, 11speed rim brakes unfortunately.
It sounds like shimano seems to be the best way to go. I have always preferred cartridge bearings as opposed to the cones in the shimanos, and have always been a hope guy on my mtbs, but they are very expensive for the rs4's and no second hand ones come up.
Posted : 07/11/2017 4:18 pm
https://www.planetx.co.uk/i/q/WPFURSPO/fulcrum-racing-sport-clincher-wheelset for £89?
The disc version came by default on my Cube, they're £144 on PX at the mo for bolt thru, pretty decent wheels.
Posted : 07/11/2017 4:25 pm
I'd go shimano, but get 105 or ultegra for the new bearings which don't need 2 cone spanners. I never had a problem with cone spanners but the new ones are witchcraft.
Posted : 07/11/2017 4:45 pm
 Bez
Well, a 105 11-speed hub is only going to bump the price up £15, to £75 for a full wheel.
If it offers any confidence, I've used almost nothing but Shimano hubs for 25 years and at absolute worst they've needed a 20-30 minute clean up every 18 months (though obviously time isn't an indication of mileage). Deore level has been a noticeable step down from LX/105 level, but eveything from that point and upwards has been magnificently reliable and maintenance-free. My last full-time commuter has done about 6000km on a Deore hub that I'd previously used for a few years of mountain biking, and it now needs the cones tightening for the second time. (From experience I'd expect higher-level hubs to do at least twice the mileage between services compared to a Deore.) I suspect (having ridden it slightly loose for ages) the cones are now pitted as well, but frankly it's not a big deal: the hub isn't going to damage anything other than its own cones, so you can keep on running a cup and cone hub into the ground with no ill effects other than very slightly increased rolling resistance.
Posted : 07/11/2017 4:46 pm
[url= https://www.ribblecycles.co.uk/shimano-pr-whls-r501-30mm-bladed-clincher/ ]Shimano R501[/url]'s cheap as chips (£80 here but I got mine for £60, shop around, wait for bargains).
use and throwaway but they are pretty long wearing.
Posted : 07/11/2017 5:26 pm
I've got Aksium Discs on mine and they've taken some right wallops. They certainly aren't light, but they seem pretty damn tough. I'd Hazard a guess the non disc ones are similar.
Posted : 07/11/2017 5:37 pm
