I'm thinking of trying a short-nosed saddle on my Broken Road (a fairly relaxed XC bike) as I'm a huge fan of them on road bikes. I've got a Spesh power saddle on my road bike at the moment so I can swap that over to try it for a few rides, but I have a couple of questions for anyone with experience of doing something similar:
- The saddle shouldn't break apart into a million shards just cos it's on an MTB should it? It's an expensive saddle and I don't want to break it.
- Anything clever I should do with positioning the saddle, or should I just plonk it in roughly the same place as the MTB saddle and go from there?
Thanks for any advice!
Ever since finding that a Fizik Aliante is just the right shape for me, I've always ridden one on every bike (its a dedicated road saddle). I've even run the superlight carbon fibre shell and braided rail version on my XC bike. I wouldn't think of changing now as I just find it so comfortable.
TLDR: It'll be absolutely fine, crack on.
As above itll probably be ok, but Fizik do an offroad saddle now that is almost identical called terra argo, might be worth a look.
I've been using superlight carbon-railed 4ZA saddles road saddles on road, CX and MTB for years with no dramas.
Similar 'shaped' saddles on all bikes. None specifically marketed as MTB.
I use a Bontrager Aeolus which is a similar idea. Half of the Trek Factory Racing Team do too so it can't be such a daft idea 🙂
Use whatever saddle works best and don't over think it 🙂
It is about pelvis angle and/or saddle tilt, if you can get them to match they will be fine.
– The saddle shouldn’t break apart into a million shards just cos it’s on an MTB should it? It’s an expensive saddle and I don’t want to break it.
I used to race XC on Selle Italia SLR saddles with Ti rails - would regularly snap the rails, gave up in the end after breaking the third one in a year!
I've never given this Amy thought - swap saddles around bikes without problem
Surely it's compulsory to use XC, Enduro, Gravel, Road, eBike, cyclocross, tandem, unicycle specific saddles
I use carbon San Marco road saddles on my MTB's as they are the perfect fit for me, I've never given it any thought I was just happy to find a saddle that works for me, the only saddle that I have broken was a MTB one.
Do you have a different arse for mountain biking?
Nose it down a bit if on your FS, as sag changes effective saddle angle when seated.
Thanks all!
Who'd have thought that a bike component choice could actually be simple?
If you don't want to break your spesh saddle google EC90 saddle. It's a copy, same shape, available for £20-25 depending on source. I have one (now on my turbo bike) which I used to try before buying my 'proper' power saddle for my road bike.
I've recently moved to an Ergon on my mtb, it's a bit shorter than the Fizik it replaced.
My ANVL saddle that arrived on my 2015 TR Scout is the comfiest saddle I have tried.
I have one for each bike now and a spare just in case, one of which is my Kona Jake CX / road / commuter.
You certainly need one of these. And it's not going to work too well on your Pinarello
The only obvious point is that you generally sit in quite a different position on a road bike. Handlebar to saddle heights will be different so this might not make the comfort transferable. Most above don't seem to have an issue, but you could.
Look at the Fabric website where they divide the range across different seating types.
