Road front deraille...
[Closed] Road front derailleurs - braze-on vs. band-on
5 Users
My "road" bike has a braze-on mount front derailleur. It seems to me a crap mounting a derailleur. Difficult to get set in the right position both vertical and yaw, and lots of play from either bolt movement, mount bending or both.
I need to change derailleur anyway (3x to 2x), should I cut it off and buy a band-on derailleur? Or if I get a better quality one (current is Sora) will it be better and matter less being 2x anyway?
Posted : 06/08/2017 5:58 pm
Nothing wrong with braze on front derailleurs at all. It's the only option available for road Di2 for a start.
Posted : 06/08/2017 6:09 pm
Very true.
However, some of the 'braze ons' these days leave a lot to be desired and can snap off or have the bonding or rivets fail
I've had to reattach a couple....
You can always use a braze on adaptor 🙂
Posted : 06/08/2017 6:12 pm
 aP
I tend to buy braze-on front mechs so that they're transferable with a different mount.
Posted : 06/08/2017 7:25 pm
Before you remove the bracket, check that a band-on mech would work i.e. your seattube is round and of the right size - many are oval or 'square'
Posted : 06/08/2017 7:42 pm
OK, perhaps it's just me/quality of current mech then. Cheers
Posted : 06/08/2017 8:28 pm
