Road frame material...
[Closed] Road frame material question?
14 Users
 ton
for a big powerfull rider, is a stiff aluminium frame better than a steel frame?
Posted : 23/02/2011 7:21 pm
Would you rather it bent,
Or snapped?
Posted : 23/02/2011 7:22 pm
 aP
Depends how lightweight or not the frame is.
Posted : 23/02/2011 7:23 pm
FAIL
It depends how it's designed.
Off the shelf alu frames are likely to be stiffer, but you can get a custom steel to ride how you want.
Off the shelf carbon is probbers the stiffest generally.
Posted : 23/02/2011 7:26 pm
Depends.
The 'big powerful' riders on any pro team ride the same as the other guys, apart from odd exceptions like Magnus Backstedt.
For your average 'big powerful' (ie, a bit chubby and clumsy) amateur it matters not a jot.
Posted : 23/02/2011 7:27 pm
Forget ti, it'll be like sitting atop a wet noodle
Noodle it and go for best of both:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=300526611426&ssPageName=STRK:MEWAX:IT
Posted : 23/02/2011 7:31 pm
Have you considered beryllium? Great frames for big lads.
Posted : 23/02/2011 7:45 pm
 CHB
Ton, you are quite welcome to have a spin on my PX Sportive Ti if you want to test BB flex. Obviously since you are at least a smidge taller than me then it won't fit you, but it might prove the point on flex.
(PS Hope you are a bit better mate, had meant to email, but crappness prevented).
Posted : 23/02/2011 7:51 pm
crikey - Member
Yet another FAIL.
It may matter quite a lot t the individual.
Posted : 23/02/2011 7:55 pm
Whatever.
Posted : 23/02/2011 7:56 pm
My mate Ian is similar physique to yourself(you met on the cold, v-wet stw aborted ride) he got himself a custom built Dave Yates, called Big Dave 😆 He uses it for touring so depends what you intend doing, racing or touring?
I have an old Ti Raliegh I got through lbs when Raliegh were closing down and there were some surplus warranty frames lying around.
cynic-al - Member
FAIL
Correct.
The frame I have has a front mech mount riveted to the seat tube and "strong" riders have broken these frames at that point. Think standing & sprinting, something I dont/cant do due to dodgy knees ❗
Posted : 23/02/2011 7:58 pm
 ton
conrad.........cheers mate, might hold you to that.
a lot of years ago i had a cannondale roadbike, not very comfy, but very fast and direct feeling.
longish road rides were a blast on it.
longish road rides on a dawes steel frame and a aravis steel audax frame seemed somewhat of a chore.
Posted : 23/02/2011 7:59 pm
crieky...hard day?
Seriously though - of course it matters **** all to performance, but it's about how the bike feels for the OP, no?
Posted : 23/02/2011 8:10 pm
[i]Seriously though - of course it matters **** all to performance, but it's about how the bike feels for the OP, no?[/i]
That's a much more acceptable response than FAIL, no?
Posted : 23/02/2011 8:12 pm
I have a couple of road bikes. One cost a lot and was ridden by Lance on one of his tour wins, the other cost £500 ten years ago. I like both. If I knew then what I know now I might have saved a few quid. Look at a Bianchi via nirone. They are always coming up on ebay. Here is a 61"
http://cgi.ebay.co.uk/Bianchi-C2C-Via-Nirone-61cm-Road-Bike-/230589702037?pt=UK_Bikes_GL&hash=item35b0379f95
Posted : 23/02/2011 8:19 pm
crikey - Member
Yes but my response included:
If in doubt, imagine a " 😀 " in all my posts.
Posted : 23/02/2011 8:21 pm
 Bez
Personally I don't like steel road frames. To be stiff enough at large sizes they end up heavy and dead-feeling compared to a decent aluminium frame. Not that I've gone the custom route.
Posted : 23/02/2011 8:22 pm
That's my point - I've ridden a 27" Rourke steel custom that was luvverly.
Anyway going by your inbred you ride a 21" road frame yes?
Posted : 23/02/2011 8:25 pm
 Bez
Whereas my point was clearly qualified by the first word in my post, and the last sentence.
63cm, FWIW.
Posted : 23/02/2011 8:49 pm
Oooh get you, Mr Serious! Worse than a lawyer!
I appreciate your last sentence, however it was a non-statement re. large custom steel frames (for the man at large...see what I did there?), mine was a positive.
None of which creates any logic as to why you'd ride a 63 when you ride a 16" mtb.
Posted : 23/02/2011 8:52 pm
 Bez
If in doubt, imagine a " :)" in all my posts.
One man's "non statement" is another's caveat and context.
Anyhow, re frame sizes. On a road bike you have two riding positions, you're in one of them for 90% of the time. So the important thing is to have a fit that's good for that. On an MTB you (I) want to ride fast over rough ground, which means I don't spend much time in the saddle, so the important thing is something that handles well and can be moved around under me easily, hence using the smallest frames I can get away with.
Posted : 23/02/2011 9:00 pm
what does powerful mean? 😉 A Colnago Master x-light will handle more power than anyone on here can put out.
How a bike feels is very subjective (assuming it meets some minimum quality level) so its a case of whatever floats your boat.
Posted : 23/02/2011 9:11 pm
Pegoretti Big Leg Emma.
Posted : 23/02/2011 9:47 pm
But Bez I had no idea you were joking - you are like a serious elder statesman on here, like Fred etc.
Anyway all of our opinions are, by definition, personal.
Posted : 23/02/2011 10:18 pm
 Bez
If by serious elder statesman you mean facetious argumentative cock then I'm with you 🙂
Posted : 23/02/2011 10:33 pm
Tony - my road bike is a Steel Le Mond LE Croix De Ferr with Carbon forks and I find it very comfy indeed. Flex is not an issue.
Posted : 23/02/2011 10:59 pm
