"Road" br...
[Closed] "Road" brake levers and vee-brakes
5 Users
Thinking about converting my flat-bar hybrid (with vees) to full road drop bars and sti levers... How will the vee's work with the levers ?? Do I need "travel-agents" or anything like that as I believe the leverage changes ?? Thanks
Posted : 25/11/2012 9:36 pm
They work, but it feels a bit odd, using travel agents makes them feel more like proper road brakes (just more powerful).
Just remember that unless it's already quite short in the top tube you'll want a shorter stem otherwise the drops will seem a very long way away.
Posted : 25/11/2012 9:55 pm
85mm arm mini-v's work fine with road levers.
Posted : 25/11/2012 10:09 pm
Cheers guys
Posted : 25/11/2012 10:26 pm
My comuter uses old xt v brakes with tiagra sti
There is a lot of lever travel but also lots of power
Its been like it for 4 years and never found the need to fit the cable pull adjuster things
Posted : 26/11/2012 7:35 am
I have MTB Vees with STIs, the lever feels a bit baggy but you have a higher mechanical advantage due to the longer arms.
Posted : 26/11/2012 7:56 am
