road bike handlebar...
[Closed] road bike handlebars
10 Users
should the drops be level with the ground?
Posted : 16/02/2012 2:50 pm
The drops should be whatever angle they feel comfortable to you at, I think mine are around 10 deg upwards, many are higher.
Posted : 16/02/2012 2:51 pm
i always used to think that... i now run with the tops level with the groud and the hoods angled slightly up.... much more comfy
Posted : 16/02/2012 3:06 pm
OP sit on the bike with the bras loose in the stem, then position yourself in the drops and see what's comfy. A balance between not sliding off the back and not feeling pushed to the front is what I aim for.
Then set sti position
Posted : 16/02/2012 3:26 pm
Usually level or slight angle, if they're like 20deg+ then you're probably doing it as an easy way to rotate the hoods up as the bike doesn't fit properly...
Posted : 16/02/2012 3:28 pm
some bars are quite different to others.
I have the same bars on both bikes and they are at quite different angles. (mostly due to a 10mm shorter ETT)
Posted : 16/02/2012 3:42 pm
cheers guys will play with it tonight.
Posted : 16/02/2012 4:29 pm
I was told they're always somewhere between horisontal and pointing at the rear dropout and set them up on that basis.
Posted : 16/02/2012 4:38 pm
i have the tops flat so i can rest my forearms along them, and the drops at whatever angle that makes them - if i'm on the drops i'm usually forward so i can reach the brakes anyway, really only use the ends if it's particularly windy or i need a change of position.
make the bits you use most of the time work for your style of riding.
Posted : 16/02/2012 4:39 pm
Theres a million different types of drop bar shapes so no hard and fast rule. I set mine up to be comfortable on the tops since thats where i spend most of my time, and that means they are flat.
Posted : 16/02/2012 5:16 pm
cycnic-al,I prefer the "bras" to be out of position,but your "not sliding off the back" is good advice.
Posted : 16/02/2012 5:43 pm
Used to point them at the back axle, and then adjust from there for comfort.
Posted : 16/02/2012 5:58 pm
