Help!!
I've had a road bike given to me and its never been quite right...but never had chance to properly look at it.
Gears never worked properly........
10 speed Campag Triple up front.......with a 9 speed campag rear derailleur and an 8 speed cassette. I'm assuming the shifters are 9 speed and the front mech.
Lovely start!! dont ask what speed the chain is, i daren't look.
might be worth reading [url= http://www.ctc.org.uk/cyclists-library/components/transmission-gears/derailleur-gears/shimergo ]this[/url] before you throw it all away - just might make sense
Err..nice article although i'll have to put m thinking head on to understand all that!
OK
Campag Mirage 9 speed rear mech.
Campag Centaur 10 speed Front Triple
Campag Mirage Front mech...no speed indicated
Campag Veloce on the brake lever so i imagine the shifter is the same??
so you need to count the clicks on the RH shifter - hopefully that'll tell you what it should be
The triple chainset will be fine with 9 or 10sp chain (not sure about 8sp)
taht article is about mixing campag / shimano parts to get them to work smoothly. If you're all campag (inc cassette) then it's irrelevant anyway
The front mech isnt a problem, that should work.
The rear cassette - really 8 speed?
If so, you may be better just selling it on (to me!) and buying a 9 speed wheel - they are dfifferent, and last time I looked, could not be interchanged like 8/9 shimano.
Or, it may be possible to buy an index piece for the shofters, but that'll be £30ish, so more cost effectigve to buy a 9sp wheel and cassette.
I'm still on 8 sp campy on my cross bike so always interested in any 8 speed parts.
Alan.
Voila the Freehub , so this wont take a 9speed campag cassete??
[img][url= https://farm6.staticflickr.com/5582/15148354426_20051bfb16_z.jp g" target="_blank">https://farm6.staticflickr.com/5582/15148354426_20051bfb16_z.jp g"/> [/img][/url][url= https://flic.kr/p/p5Bh1A ]Untitled[/url] by [url= https://www.flickr.com/people/100513049@N06/ ]ben_eddie[/url], on Flickr[/img]
Rear Mech
[img][url= https://farm4.staticflickr.com/3864/15171010982_4d5fbf8620_z.jp g" target="_blank">https://farm4.staticflickr.com/3864/15171010982_4d5fbf8620_z.jp g"/> [/img][/url][url= https://flic.kr/p/p7Bp1S ]Untitled[/url] by [url= https://www.flickr.com/people/100513049@N06/ ]ben_eddie[/url], on Flickr[/img]
Front Rings
[img][url= https://farm6.staticflickr.com/5591/15171003462_8cc5901a09_z.jp g" target="_blank">https://farm6.staticflickr.com/5591/15171003462_8cc5901a09_z.jp g"/> [/img][/url][url= https://flic.kr/p/p7BmMd ]Untitled[/url] by [url= https://www.flickr.com/people/100513049@N06/ ]ben_eddie[/url], on Flickr[/img]
Shifter
[url= https://farm6.staticflickr.com/5566/14984821967_f6821a083b_z.jp g" target="_blank">https://farm6.staticflickr.com/5566/14984821967_f6821a083b_z.jp g"/> [/img][/url][url= https://flic.kr/p/oQa8vr ]Untitled[/url] by [url= https://www.flickr.com/people/100513049@N06/ ]ben_eddie[/url], on Flickr
Basically it has worked just badly in the past. so I figured a new 9 speed cassette would help
Hard to tell much from that shot as cannot see all the splines. a quick search suggests that 8 is not compatible with 9 die to a change in the free hub body.
Campag 9/10 speeds are definitely on the same free hub. 11 is same + a spacer iirc.
I have a spare relatively cheap and little used campag 9spd rear wheel, no cassette, cluttering the place up if that were of interest/ needed.
Thas a shimano free hub isnt it ?
50 p on he has campag 9 speed shifters and mech driving a shimano 8 speed casette as that damn near works with an extra click. Works even better if you alter the clamp angle slightly.
the cassette is definitely campag. I'm annoyed as just bought some Pikes for the fun bike. Now i've got this to sort out.. I wish id never brought it home from the father in laws.
My bad was looking on the phone.
Looked on the big screen its 8spd campag , yep only 8speed campag will fit that.
9 speed campags a different fit
New wheel time im afraid
[url= http://branfordbike.com/articles/cassettes-and-cogs-pg60.htm ]cassette[/url]
Just found this link..looks like the Exa-Drive 8 speed Campagnolo freehub. Bugger
garage dweller, how much for the wheel??
Postage + something for a pint would probably do the trick. Let me check weight and postage costs later this evening. Will pop my email into my profile later too when I am not on the phone.
According to [url= http://en.wikibooks.org/wiki/Bicycles/Maintenance_and_Repair/Gear-changing_Dimensions ]this[/url]
Campag 8 speed stacks up to 36.9mm while Campag 9 speed stacks up to 38.2mm, so 1.3mm difference for the cassettes, and 0.45mm smaller pitch...
On top of that Campag 9 speed has two possible cable pull ratios, depending on when it was made apparently, so are you sure the mech is speaking the same dialect as the shifter?
No idea! This really is complicated.
Ill have it.
It'll still be pink.
Pink is the least of its worries....the fact its a mismatch of campag components isn't helping.
Next question do i need a campag specific chain?
Email sorted but late home from work so not looked at postage yet. If you want it ping me an email and will get back to you tomorrow some time. Best guess is probably looking about 20-25 posted.
Cheers, email sent.
