Road Bike BB help p...
[Closed] Road Bike BB help please !!
6 Users
Seems I have a 42mm bottom bracket hole in my new road frame. Its unthreaded, but is baffling me on what I need to put into it? I am guessing at a KCNC BB30 style, but has anyone got any recommendations or help on this. I will be fitting a set of 105 cranks onto it, so a 24mm dia bearing.
Posted : 28/02/2013 4:48 pm
Something like this perhaps?
[url= http://wheelsmfg.com/bb-30-shims-shimano.html ]http://wheelsmfg.com/bb-30-shims-shimano.html[/url]
Posted : 28/02/2013 5:06 pm
Have you measured it correctly, 42mm isn't matching anything i've checked. If it's 41mm, then it'll be a Shimano PF(insert shell width), from what i've just sourced.
Posted : 28/02/2013 5:43 pm
its likely an 86.5mm press-fit bb which shimano do for their cranks.
Posted : 28/02/2013 5:48 pm
Just remeasured it at 41.9mm and 68mm standard width. Last bit I need to build the bike is this. One standard would be a bonus for all bikes and less of a headache.
Posted : 28/02/2013 8:49 pm
What bike is it. Some specialized use a 42 mm bb92 I think.
Posted : 28/02/2013 9:46 pm
Has it got 2 grooves in it about 10mm in from each side?
Posted : 28/02/2013 9:56 pm
Its a Dolan Hercules carbon. Dolan have been a bit pants on helping to be honest and nothing on their website either.
It has a step about 6 to 7 mm into the shell to then be about a mm wider again.
Posted : 28/02/2013 9:59 pm
It's bb30.You can fit a bb30 bb and then those wheels mfg adaptors up there or one of these and use your ht2 cups
Posted : 28/02/2013 10:04 pm
Cool, where can I get one of those shims?
Posted : 28/02/2013 10:06 pm
[url= http://qwertycycles.co.uk/collections/bottom-brackets/products/cannondale-bb30-adaptor-68mm-kp009 ]here[/url]
Tbh honest it's probably something that's better fitted by an lbs (and a cannondale dealer).It's not permanent but it has to be pressed in and is a whole lot easier with the right tools...and they'll put it in the right way round.
Posted : 28/02/2013 10:10 pm
Cheers mate, all ordered. I have a headset press and sure with a bit of common sense, we can get it fitted. Do I use any loctite on this before I press it in?
Luckily BB's are marked on direction and side to go which side.
Posted : 28/02/2013 10:18 pm
You'll get some bearing fit with it.It is marked which way round it goes....though sometimes apparently I choose to ignore that 😳
Posted : 28/02/2013 10:34 pm
Oooops, I guess I'll RTFM before I do.....( Read The F******* Manual). Groupset wont be here until Tuesday, shopping for bars today and then thats it, all bought.. Roll on next weekend for the first ride.
Posted : 01/03/2013 7:54 am
