I am looking to purchase the below but I would like to swap out the FSA crnakset for a shimano 105 crankset so that I can use my power meter with it (a 4iiii one).
https://www.boardmanbikes.com/gb_en/products/2341-slr-8.9-2021.html
As it is a pressfit bottom bracket do I just need one of these and then can fit a normal 105 crankset. Thanks!
https://www.sigmasports.com/item/Shimano/SM-BB71-PressFit-Bottom-Bracket-865mm/QNJ
Yep
ps. I think the MegaExo one that came in the frame will almost-but-not-quite fit the Shimano - pretty sure the FSA has a step in the crank axle that makes them incompatible. But I'm happy to be corrected.
That was an easy one! Thanks đŸ™‚
Yep, assuming it's a BB86 frame
Not familiar with the FSA cranks, would it not just be a straight swap without changing the BB?
e2a: @desperatebicycle has answered that one
Yeh this is the bottom bracket that is in there.
FSA BB-CF86/CZ Pressfit for MegaExo Chainset
assuming it’s a BB86
I looked that up, me đŸ˜€
Have a look at the Token Ninja BB. It's a little expensive (if you can find one) but it has loads of shims and also screws together in the middle so it doesn't creak at all
