Hi all,
Would like to convert a Rival AXS chainset from 2x to 1x - is this just a straightforward case of removing the 2 and fitting the 1 ?
Spoke to Garbaruk and they say this will work
https://www.garbaruk.com/shop/product/107-bcd-oval.html?category=6
But just want to make sure before ordering.
And if it does work, then anything else I need ?
TIA
The chainline is unlikely to be as good as with a 1x chainset as the two chainrings are offset from the ideal 1x position.
Does anything else use 107BCD chainrings? Why is there yet another size? I’ve just had a clear out and have found 94, 96, 104 and 110 all on the shelf 🙄
Sorry that’s not answering your query obviously.
Emailed SRAM just to check and unfortunately can’t be done as it’s a fixed spider - so will have to find a 1x crankset
Thanks for the replies all the same
