rims for v-brake wh...
[Closed] rims for v-brake wheels. Upgrade from Mavic xm317 to xc717 or not?
4 Users
just bust another Mavic xm317 rim after a years use( may add I was used these rubbishy Gigapower brake pads at start so that wore them down quite a bit,usually put on Koolstop pads of course).Now that I need a new wheel I am thinking of upgrading to an Mavic XC717 rim and I wondering if this is worthwhile for me.Is the Maxtal rim material apart from being slightley lighter and stiffer also more hardwearing for brakewear?
Posted : 22/07/2013 10:59 am
Not what you're asking really, but I recently put a pair of Crossrides (an older flat bladed set) on a bike as an upgrade from some older Mavic rims. Although not much lighter than the previous wheels, they were a million times better in all respects. Stiffer, more responsive, and better at stopping.
You can get them off Ebay for about £100 or less for a 2nd hand set. mine are actually dual duty, ie V-brake and a disc hub.
Posted : 22/07/2013 11:05 am
I am actually looking at a fairly lightweight custom wheel build with XT m770 hubs and DT Comp spokes and I am not sure if the Mavic XC717 rims wear better from braking.That is the only reason why I would upgrade.I have read somewhere that they do but just not sure.
Posted : 22/07/2013 11:15 am
I have XT m770 hubs, DT Comp spokes and Mavic XC717 rims for v brakes and they seem good. I was also worried about how log they would last because I was replacing some old mavic ceramic rims, but the 717s do seem OK and arnt wearing obviously too fast
hope that helps
Posted : 22/07/2013 12:26 pm
Not really much in it, the only notable upgrade would be to ceramic, but your wallet would probably have a right old tantrum.
Posted : 22/07/2013 12:40 pm
