Hi guys,
My reverb has developed a sag of about 20mm I have checked the usual stuff. The post came fitted to a second hand bike I purchased so no warranty. Has anyone got any advise as to whom maybe able to repair it? Don't really want the post off the bike for ages as I am booked in for uplift at BPW next Monday. Or am I asking for a massive bill and would be better off buying another one? And selling this one as spares?
Many thanks
Russ
Get your LBS to send to Fishers?
It came with the bike and as such not bought from LBS and will be out of warranty because of this. Are fishers not just going to want to replace with new? Have you had experience of them repairing them, if so what kind of bill did you have?
I also have a problem with my reverb doing this, its out of warranty now so I'm wondering whether the cost is going to be great enough to justify a far more serviceable thomson dropper.....
I am thinking the same, I have found a company that will service and repair for £55, which sounds brilliant although almost too good to be true. I have had loads of reverbs over the years and all have had problems. My old KS Lev was faultless it really was. Will report back when I receive post back from repairers unless anyone else can recommend somewhere else.
Just use an old fashioned seat post at BPW and leave it dropped, then take your time to choose the right place to get it fixed.
If your on good terms with your LBS then get them to send it back to Fishers. They will very likely replace it for a brand new boxed one, even if its out of warranty. Worst case is they charge you £75 for a full service.
Thought of that mugboo, sadly it would involve me buying one.
My local 'man in garage fixing bikes' type business Belper Bikes charges £50 for a reverb service, he did mine that had the same dropping an inch issue, including replacing most of the seals for £54 (he needed a few more seals than if it was a standard service
It is honestly, after a good few rides on it, better than it was from new, there is zero play at all
So no reason why £50 should be too good to be true
What size do you need? I have a spare 31.6 if your local to Brighouse?
Where services for £55. Have got the same issue with my stealth reverb.
Would like to get it fixed
SRAM are pretty good about fixing their problematic dropper posts.
Call you LBS, they can handle the warranty return on your behalf. Last time I was charged a few quid, took about a week to get a new post back though...
