Reverb Stealth prob...
[Closed] Reverb Stealth problem
4 Users
My Reverb has got slower and slower over the last couple of months. It currently only extends about 3/4 of the way through its travel.
Tried a full bleed earlier and it doesn't seem to have made any difference.
Any idea what might be causing this?
Posted : 02/03/2016 9:24 pm
Kinked hose/cable?
Over tightening of the seat clamp??
I had an issue with mine and the cable was kinked in the frame
Posted : 02/03/2016 9:26 pm
Checked the air pressure is at 250psi?
Posted : 02/03/2016 9:30 pm
I know this is a silly question but have you checked the air pressure?
Other than that I would say that the main piston seal head has become slightly loose allowing the oil to slowly escape past the seal, slowly leading to the point that you are at now.
If this is the case no amount of bleeding will sort it you'll need a full service.
If its fairly new then its a warranty issue.
Posted : 02/03/2016 9:31 pm
