Reverb stealth Blee...
[Closed] Reverb stealth Bleed Help
8 Users
I'm probably being stupid, but what methods do you use for bleeding your stealth reverbs? I can't get the lever to return properly. With 2 syringes I remove all the air from the line nicely, then switch to just the lever end and I just keep pulling syringe after syringe of air out when creating a vacuum with the button pressed and I can't figure out why. If anyone has a fool-proof method including position of the speed dial etc. etc. then I'd be most grateful.
Posted : 12/01/2016 1:38 pm
Very detailed instructions on the SRAM website/Youtube channel.
You need to pump the button in a few times. Speed dial needs to be turned fully one way too.
Posted : 12/01/2016 1:45 pm
I've tried that and never had any issues bleeding my old non-0stealth, but this time with the button depressed I can just keep pulling air out of the lever until the syringe is full of air and then do it all again like there's a leak, but I've even swapped out the lever and checked everything and it seems fine.
Really frustrating.
Posted : 12/01/2016 3:36 pm
I had this. seal on syringe connection to remote was leaking, the air wasn't coming from the remote.
Posted : 12/01/2016 3:39 pm
Posted : 12/01/2016 4:34 pm
Tried all the methods and even changing syringes, but I still get the never ending stream of air coming out of the lever. Really don't know what to do about it now.
Posted : 15/01/2016 3:40 pm
 LoCo
The syringes with draw air in with little provocation, either that or you have a leaky barb/hose joint
Posted : 15/01/2016 3:43 pm
Try this. Instead of using the syringe as a syringe, remove the plunger and just use it as a fluid reservoir. Cycle the plunger and it should pretty quickly clear all the bubbles.
I did a full rebuild on my Reverb Stealth last night and finished the bleed using this exact method.
Posted : 15/01/2016 3:52 pm
I fitted a steath reverb I'd taken off another bike about 4 months ago and despite it having being lying around for that long and having very little fluid left in it I just did a remote bleed and it seems to be working perfectly. I followed this [url=
remote bleed[/url] HTH
Posted : 15/01/2016 6:09 pm
Epic Bleed Solutions have pretty good instructions.
http://www.epicbleedsolutions.com/resources/instructions/
Posted : 15/01/2016 6:15 pm
