Took the wife's reverb apart for a clean. Just wondering if people just grease, or a heavy oil (like float fluid) when doing this.
quick squirt of Fork Juice and a wipe down seems to be good
I meant inside. After each ride it gets a wipe down and a little stanchion lube.
What I've done is taken it apart as if you were doing a lowers service on a fork. Not bothered going into the damper.
Anyway, if anyone is interested, it's grease, not oil. The reason being that there are three fine breather holes covered with a felt washer. Use oil in it and it will just dribble/squirt out in use.
ah ok. Not had mine to bits yet !
I'm tempted to strip mine down it seems to loose air over time. Any guides online?
If it's losing air, I'd be tempted to try a new schrader valve. The air chamber isn't exposed by a simple strip down.
Was there a guide you used when doing it? Never done mine.
sram do their own videos but it's not tricky if you've got a strap wrench or a set of soft jaws for a vice.
