Reverb, Pitch - Con...
[Closed] Reverb, Pitch - Confused?!
3 Users
Not sure if im being dim here;
Has anyone got a reverb on a medium size pitch.
Looking to buy one but can't figure out the size.
The seatpost I have is 300mm long. If i lower it as far as possible then thats about 145mm drop. So If I want a 125mm drop reverb, which is 380mm long then I don't think it will drop fully?
Posted : 07/11/2012 9:13 pm
Search the last week's threads on min exposed post. Been done already this week.
Posted : 07/11/2012 9:14 pm
I've got the longer version and a medium pitch, fit's in a medium pitch fine without hitting anything in the frame. There's around 190-200mm of post showing between the saddle rails and the frame at the minimum, I run mine with about 1.5" of post showing between the reverb's collar and the frame.
Posted : 07/11/2012 9:24 pm
Found the previous topic, big help. I have about 210 of post showing at full extension.
As long as the 380mm is when fully extended will fit fine.
When you say 190-200mm of post showing at minimum, do you mean fully extended?
Posted : 07/11/2012 9:41 pm
