Reverb newbie quest...
[Closed] Reverb newbie questions
2 Users
Reverb fitted today, couple of queries if you could be so kind :
- the silver collar - presume this in case of a failure on the trails ? do you fit at top of shaft, or carry in pack ? if the former, does it scratch the shaft ?
- secondly, any easy way to get rear crudcatcher on the lower bit and not foul the hose ?
thanks
Posted : 08/05/2013 2:02 pm
The silver collar is to set the maximum lower drop height if you don't wish it to drop the post entirely down every time, i dunno bout the fitting of the crudcatcher? - be careful as the crudcatcher might rotate round the seatpost if you come off in a crash and it may detach the hose as they are attached quite delicately at the seat clamp area.
Posted : 08/05/2013 2:09 pm
thanks, think I'll pop the collar in my camelbak. Will need to think about mudguard, as the twisting round thing is a reality indeed, cheers
Posted : 08/05/2013 2:16 pm
If you're wanting a mudguard to keep your arse dry then i can recommend the [url= http://www.muckynutz.com/ ]Butt fender from MuckyNutz[/url], also, their bender fender is a far better design for keeping mud and grit off your fork stantions than the neoprene items that attach to fork braces.
Posted : 08/05/2013 2:21 pm
somafunk - thanks, I have the front one, which I use in combination with a downtube crudcatcher (spec wearer so like a clean face 😀 )so might get hold of that back one, cheers
Posted : 08/05/2013 2:34 pm
