Reverb lifts up by ...
[Closed] Reverb lifts up by saddle - normal?
7 Users
Question for reverb owners - is it normal that if I lift the bike by the saddle the reverb post extends? It pulls itself back down if you let go. Never noticed it before, but not had one for long so guess I may never have lifted the bike with the post down.
Thanks in advance.
Posted : 03/03/2013 5:53 pm
Same thing happened to me - guess its normal.
Mine works flawlessly all the time so can't be faulty.
Posted : 03/03/2013 5:56 pm
 bigG
Yes, it's normal
Posted : 03/03/2013 6:08 pm
Cheers guys 😀
Posted : 03/03/2013 6:11 pm
Only happens in the cold with mine.
Posted : 03/03/2013 6:13 pm
Check the air pressure, make sure you have 250psi in it.
Was cold today (and had been on the car on way to trails). Will check pressure too, cheers.
Posted : 03/03/2013 6:21 pm
 sbob
Posted : 03/03/2013 6:22 pm
Yes, this is normal, however, avoid doing it as it's suggested that doing this can lead to the seals losing air due to the vacuum it causes
Posted : 03/03/2013 6:49 pm
