I know there have been posts (pardon the pun) on here but I couldn't find them in the search.
Mrs O's Reverb has suddenly jammed in the up position. Is this likely to be an airlock? It's not yet seen much use.
Any ideas appreciated before we go off on holiday with it!
Thanks
Needs a bleed by sounds of it.
Loosen the seat clamp?
Mine did the same a bleeding sorted it but also the bushes in mine are done so the seat will only drop when weight is applied to the font of the seat not the rear.
Tried the seat clamp- so it sounds like a bleed.
Thanks all. Better try to find a bleed kit. Is it difficult?
