Does the basic service kit include the o ring for the IFP in a 2015 stealth reverb? I've got 5mm of sag to try and sort out.
Thanks!
No, none of the "oil side" o-rings are in the basic kit. (AFAIK)
FWIW: I'd live with 5mm of sag until it gets worse. (Always worth checking the air pressure, too...)
Ok so after a bit of research it look like i need these for the Piston and IFP:
Piston:
7.59mm x 2.62mm x /quad (size 109 / quad ring)
IFP:
2mm x 13.5mm (2mmm x 16mm)
2mm x 16.5mm (2mm x 16mm)
Don't buy any o-rings for the IFP. Throw it in the bin and fit an upgraded one from the B1 version. It does a much better job of being an IFP.
Thanks pigyn. Do you know where i can buy one?
Here are some - http://365cycles.com/rockshox-pre-2017-reverb-reverb-stealth-internal-floating-piston-a1-and-a2.html
Are there any UK dealers you know of?
If you want one I have some. Email in profile.
Writing so i can find this thread later
