Reverb hose cutting...
[Closed] Reverb hose cutting immediate help require please!!!
5 Users
Ok, literally sat here with the hose cut, bu, I just can't get the barb of the control to screw back into the hose???
What am I doing wrong?
I've tried forceful, light, clockwise, counter, it just wont start screwing in???
Thanks!
Posted : 08/01/2013 6:58 pm
Cut lengthways with a Stanley knife blade
Posted : 08/01/2013 7:02 pm
cut what lengthways? I'm a little confused?
Posted : 08/01/2013 7:03 pm
Force with a jiggle. Use something to grip the hose.
Posted : 08/01/2013 7:06 pm
Sorry my mistake, I thought you could not get the hose off the barb.
If your trying to get the control onto the hose just screw the whole lot in and then mount the control
Posted : 08/01/2013 7:07 pm
its screwing the bit in that will not comply...
Posted : 08/01/2013 7:10 pm
I think the older ones (IIRC) you have to tap in, the newer ones are threaded.
I used those yellow plastic things you get with shimano brakes to grip the hose (in some molgrips).
EDIT - I'm talking about getting the barbed fitting into the hose - I'm now not sure if that's what you're asking about.
Posted : 08/01/2013 7:11 pm
YES!!!!!!! DONE IT!!!
hairyscary I thank you! Having the hose attached by an elastic band to the bar let me use both hands to screw in (tricky shape to screw the push button)
Thanks for the help!
(pretends he wasn't super stressed!)
Posted : 08/01/2013 7:12 pm
the pad spacers with Magura brakes have a 'hose holder' built into them that means you can get some force behind putting a new insert in when you trim them. As you found it's a right pain without.
Posted : 08/01/2013 7:16 pm
I think the main thing was, the tech video I watched warned about putting it in straight as to not snap the barb, so I just presumed it was a weak item but evidently not that weak 🙂
Posted : 08/01/2013 7:23 pm
