Hi guys. I needed to bleed my reverb as it stopped returning and after 2 hours of fruitless effort I realised I had a leak on the post connection end. I fixed it and rebled which worked much better but I now have a slight, maybe 15mm sink on the saddle when I put weight on it. It returns and does what it should but I'm sure it shouldn't go down a little when weight is applied. The air pressure is around 250 psi so I'm now stumped. Any advice appreciated Thanks.
Stubborn air bubbles. Keep bleeding mon ami.
Really? Thanks mate I better leave it for tonight with all the valentines stuff going on but I will rebleed tomorrow. Cheers.
Sinking when you sit on it doesn't sound like a bleed issue tbh. The manual does say if the post still drops a bit when you sit in it, it needs to go back to the manufacturer. Is it still under warranty?
No mate its not, it never did it before the leak and now does after my repair.
I've just found out if you pump the remote the post goes solid. So maybe it is the bleed after all.
