Has anyone found that a Reverb doesn't go up/down far enough? Thinking of getting one as an upgrade with a new bike, but I'm concerned that it wont travel enough and I'll end up having to adjust the seatpost the normal way as well.
Any 6ft2" plus people out there can help me out?
see yesterdays thread
measure the drop you use on your post with a tape measure, really easy.
If a 420mm seatpost with 125mm drop isn't enough perhaps more of a problem with frame size & riding [s]ability[/s] sorry I mean 'style' ?
Alternatively, don't buy a Reverb if it doesn't suit, aren't KS doing a 150mm drop post ?
I'm 6'4" on a large SC Nomad Mk1. I have a 420mm length 125mm travel reverb which goes up high enough and certainly goes low enough.
You may only have an issue if you've maxed out on frame size and have little to no seatpost showing or vice versa.
isn't the 2013 reverb going to be 150mm?
