Reverb Dropping aro...
[Closed] Reverb Dropping around 10mm
10 Users
My reverb stealth (150mm 31.6mm) has started dropping around 10mm. I have checked and topped up the air pressure to 250psi. It was at 240psi so wasn't far off before topping up. It's only around 6 months old so should be covered by warranty but before I ring sram/ fishers in the morning is there anything else that causes this that I can remedy myself?
I have had a google but everything points to the air pressure or send it back to sram.
Andy.
Posted : 06/10/2015 7:15 pm
Sounds like the known warranty issue that was going around from about 2012. It's a free warranty replacement with fishers the importers via your local bike store.
Posted : 06/10/2015 7:40 pm
Have they not sorted it on newer models? I'll give them a ring first thing. Good job the bikes out of action for a week or so so I won't be needing it for a bit.
Posted : 06/10/2015 7:48 pm
I'd have thought so but it does sound like it I had 2 that did it and fishers sorted them within a week no issues.
So that's good.
Posted : 06/10/2015 8:34 pm
 LoCo
Return to place of purchase for a Warranty return, internal issues.
Posted : 06/10/2015 8:43 pm
You may as well warranty it as above.
But, if you do a proper bleed, ie using 2 x syringes (not just 1 at the remote) you might find that fixes things. It did for me last week, though I dont really understand why?
Posted : 06/10/2015 8:45 pm
Send back to Fishers via the shop you bought it from and about 10 days later a new boxed one arrives - got one waiting for me. 🙂
Posted : 06/10/2015 8:47 pm
Had mine replaced under warranty for this issue, earlier this year.
New one is now doing the same!
Posted : 06/10/2015 8:57 pm
Had mine replaced under warranty through CRC with the same problem.
One suggestion I saw was that it can be caused by lifting the bike by the seat when it is in a lowered position. Apparently, it can suck air past the seals.
Posted : 06/10/2015 10:06 pm
Had same issue, checked air and bled properly, no change, replaced under warranty, 9 months old
Posted : 07/10/2015 12:09 pm
 Dave
[i]One suggestion I saw was that it can be caused by lifting the bike by the seat when it is in a lowered position. Apparently, it can suck air past the seals.[/i]
^^ This.
Posted : 07/10/2015 12:10 pm
Thanks for all the advice.
I rang Sram earlier and they said to send it in for warranty via a LBS. The guy I spoke to said it's most likely that air has got past a seal. Apparently its not caused by lifting the bike by the saddle which I have never done anyway.
Posted : 07/10/2015 12:24 pm
Noticed mine doing just this yesterday. How will I cope in the Oxfordshire hills without my dropper if it has to be warrantied?
Posted : 07/10/2015 1:44 pm
