Checked the air pressure and it was low but quite a bit of oil in air chamber which squirted out of the valve
suspect a seal has gone?
is this likely to be serviceable?
thanks
How old? - 2 year warranty on Sram kit
Yep, mine did this.
Warranty job.
bought on classifieds!
It'll be the oil level. You can do it yourself - the videos on the SRAM site are excellent. But you need the SRAM measuring tube or a copy of one to get the oil levels right.
It might just need bled but mine has just gone back to SRAM for this very reason.
Mine is doing the same 🙁
Yep - two of mine did this and it was fairly easy to top up the oil which fixed them..
A bleed WILL NOT fix this known problem.
A service will.
Warranty it if you have the option. You will likely get a new post back.
I've got the same problem.. but I bought the post from the classifieds.. what is the cure?
Get it serviced. Either yourself or by TFTuned, Loco etc.
