Reverb change in to...
[Closed] Reverb change in total length
5 Users
So i need i new post for a new bike and want a Reverb to match my other bike. The thing is my old Reverb Stealth (125mm drop) has a total length of 380mm but the new ones are 390mm. My issue is i need the post all the way in the seat tube so the new one will be 1cm too high.
Are there any tricks around this or will i have to go for a 100mm drop Reverb which has a total length of 340mm?
Posted : 27/06/2017 3:09 pm
buy an old one?
Posted : 27/06/2017 3:31 pm
If i could find one unused i would
Posted : 27/06/2017 3:39 pm
e-bay would be your best bet look for old unused stock. But usually they ask for the same price as the new ones.
Posted : 27/06/2017 4:00 pm
Lower profile saddle/taller pedals/thicker soles/shorter cranks?
Do they still do a 100mm drop one?
Posted : 27/06/2017 5:50 pm
What seatpost diameter? Have you just googled 'reverb stealth 380' ?
https://www.amazon.co.uk/Reverb-Stealth-Drop-31-6-Long/dp/B019OX7RV8
Posted : 27/06/2017 6:01 pm
Thats up for £349! Most places are between £230 and £250
I need 30.9.
Posted : 27/06/2017 9:17 pm
The length increase is all in the outer tube. If the seat tube will cope with another 10mm insertion, the saddle height will be the same
Posted : 27/06/2017 10:00 pm
Thats my problem. Due to the design of the seat tube I can't fit any more in the frame.
I guess my best option is to find a saddle with a lower profile?
Posted : 27/06/2017 10:12 pm
Boooyaka...could be in stock dude. Give them a call.
http://www.ciclisport.com/2235/products/rock-shox-reverb-stealth---125mm-drop--30-9mm--380mm-long--mmx-left.aspx
Posted : 27/06/2017 10:19 pm
Thanks! I'll have a look when i get home and another measure of my frame. I noticed last night my road bike seat height (from pedals) is 2cm more than my MTB's so i might just get away with an extra 1cm.
Another quick question before I buy one. I'm planning on buying it in 30.9 and using a long shim so I can swap it between bikes. I've read using long shims is fine and I do only weigh 9 stone. I am tempted though to just buy it in 31.6 but I'll be kicking myself if (when) I plan a big ride or weekend away on my full sus and the reverb on that breaks and I cant swap them over.
Does this sound sensible or am i just be silly? I'm prepared for sarcastic comments...
Posted : 28/06/2017 11:54 am
