Hi all,
I've a brand new Reverb C1 and after every ride I need to bleed using the new tool/vent valve procedure. I'm right in thinking any the air cannot be coming from the lever/hose since they are in effect two separate systems?
Any thoughts on how to solve or is it warranty time?
Cheers!
Posted : 03/06/2021 3:28 pm
Is the post at the correct air pressure? Maybe a total bleed of the system would help as it may have air trapped that is being moved during use resulting in this need.
Posted : 03/06/2021 5:13 pm
Mine went like that, SRAM did warranty without question. Replacement is starting to do the same...
Posted : 04/06/2021 9:07 pm
